I think that this is related to LabVIEW, but more basically to the Shannon theorem
😉 : if you want to describe a periodic function, you need to take enough samples. First, expand the x scale to see a delta t of 0.001 s (ie a period of your 1000 Hz signal). Remeber to set the autoscale property on OFF. Then go to "sampling info" and increase the sampling frequency. See the result...
CC
Chilly Charly (aka CC)
