Problems with displaying high frequency sine wave
Hi all,
I don't why LabVIEW has problem with high frequency display.
Someone plzzz explane me how to see a better grapth on grapth?
check this function waveform generation.vi in examples go to search and type "waveform"
set the feq to 1k.
Thanks and regards
(2,619 Views)
I think that this is related to LabVIEW, but more basically to the Shannon theorem 😉 : if you want to describe a periodic function, you need to take enough samples. First, expand the x scale to see a delta t of 0.001 s (ie a period of your 1000 Hz signal). Remeber to set the autoscale property on OFF. Then go to "sampling info" and increase the sampling frequency. See the result...
CC
Chilly Charly    (aka CC)
(2,617 Views)
