Problems with bit shift left in Formula Node
Sorry but my English is not good.
I'm trying to execute a bit shift left in the Formula Node, but the shift left is not working as I expected.
uInt32 parametro[5];
float32 valorAmostra;
int16 indiceAmostra;
uInt8 indiceResposta;
int16 controle;
int32 valor;
int8 i;
for(i=0; i<5; i++)
    parametro[i]=param[i];
valor = parametro[5]<<16 | parametro[4]<<8 | parametro[3];
controle = parametro[1]<<8 | parametro[0];
indiceAmostra = (controle & 0x3FF);
indiceResposta = (controle >> 10);
valorAmostra = valor & 0x7FFFFF;
valorAmostra = valorAmostra*(2.4/8388607);
   if((valor & 0x800000) == 0x800000)
      valorAmostra = valorAmostra*(-1);
the input param array is of the type uInt8, as I saw in other topics that does not shift with uInt8,
I copy the values of param array to parametro which is of type  uInt32, but still did not work.
Testing the input param with the following values:
param[] = {10,14,10,0,16}
the valorAmostra returned is 0,00117188 when he should be 0,300003.
Can someone help me please?
(3,509 Views)
Accepted by geovane
Portuguese:
Olá,
Existe um bug no LabVIEW para esta operação. Este bug deverá ser corrigido em versões futuras. Uma solução para esta situação é utilizar um int32 ao invés de um ulnt32.
Qualquer dúvida por favor entre em contato.
Obrigado.
English:
I investigated the problem you are having, and it turns out that it is a bug that has already been reported and documented. The work around for it is to use int32 rather than uInt32.
Thanks.
Luciano Borges
Test Development Engineer
(3,486 Views)
