Problems with Signal Analysis
I have problems with Signal Analysis.The Vi which samples value from the acquisition card is in an while loop and samples each loop a value.the values were put in an array.I want to make different signal analysis(fast fourier transformation,powerspectrum,...) with these values.The problem is, that the graph shown in the diagramm is correct,but the value on the x-axis don't match with the analysis.What have I to do?Have I to create a waveform?If yes,how?
Message 1 of 8
(4,720 Views)
I'm not sure exactly what your data format is, but if you are doing any FFT's, you are going to need the time information or your X-Axis will be incorrect (Which sounds like what you have).
So to answer your question, yes, you will need to create a waveform. Waveform->Build Waveform.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 2 of 8
(4,720 Views)
Thank you for your help!Now i have build an waveform and it works so far. But I need frequency values on the x-axis.I don't know how to get the frequency values there.At the moment there are values which are calculated out of the number of sampled values and dt used by building a waveform.
Message 3 of 8
(4,720 Views)
Not sure I understand you. Are the x-axis values different from what you want or are they wrong?
-Matt Bradley
Message 6 of 8
(4,720 Views)
When I make for example an FFT, i want to see the frequencies on the x-axis which are in the signal.But in my Labview Diagramm the values on the x-axis have nothing to do with the frequencies in my signal.The FFT seems to be correct,but the x-axis doesn't show what I want to see.I don't know what I have to change. In some NI examples it works,but I can't see why.
Message 7 of 8
(4,720 Views)
If you want to have the 'good frequencies', you must set your dt.
if you use LV6 and waveform, the dt is the inverse of your sampling
frequency.
If you use older version, you can set your dt buy bundling dt value and the
array of point. you also can set the multiplier value in the
attribute/propertie node.
dt is always the inverse of the sampling frequency.
Jerome LANGE
Strasbourg
andromed@club-internet.fr
"Colt" a écrit dans le message news:
506500000005000000EB7B0000-1021771306000@exchange.ni.com...
my signal.The
Message 8 of 8
(4,720 Views)
Colt,
Hoave you looked at the shipping examples that come with LabVIEW? There are many examples for doing Signal Analysis (Processing). This is the best place to start looking for help. There is even a Power Spectrum example. All you will need to do is to replace the generated waveform with one from a DAQ card.
Randy Hoskin
http://www.ni.com/ask
Message 4 of 8
(4,720 Views)
Colt,
Randy Hoskin
Message 5 of 8
(4,720 Views)
