Problems with Saving Data in Real-Time
Hi tpendleton,
@tpendleton18 wrote:
I did not understand the example projects in Labview. I am a beginner in LabVIEW and am developing this VI for a school project. For our project, we need to display the data using graphs (which does display data when the code is ran). I understand the basics of LabVIEW however FPGA is a whole new world for me.
So as a beginner in LabVIEW, working for a school project, you really took the FPGA part that is mostly suited for advanced LabVIEW user with knowledge about the subtle differences of "LabVIEW for FPGA"?
If there is ANY easy solution you can provide, please let me know.
Suggestion:
Use the ScanEngine when you need to use this cRIO!
(The ScanEngine supports your rather simple AI/AO modules.)
Message 11 of 15
(499 Views)
Is there a way to move the VI from FPGA to ScanEngine like you provided?
Message 12 of 15
(489 Views)
Hi tpendleton,
Yes.
  • Drag & drop the VI from FPGA context to cRIO context. (As shown in my image, you need to drop the VI on the "Chassis cRIO9064" item.)
  • Drag & drop the cRIO modules from FPGA context to "Realtime Scan Resources" "folder". (As shown in my image.)
  • Replace the FPGA IO nodes in the VI with ScanEngine SharedVariables by drag&drop'ing the IO items from ScanResources/Module1 into the block diagram… (As shown in my image.)
Message 13 of 15
(485 Views)
I have done what you said, however now I am not getting any input or output signal from the cRIO. The I/O module are not collecting any data somehow.
Message 14 of 15
(480 Views)
Accepted by tpendleton18
Hi tpendleton,
did you build your project and deployed it (completely) to the cRIO?
The cRIO target has "to know" that you changed your mind to use the ScanEngine instead of the FPGA…
Message 15 of 15
(470 Views)
