Problems with Plotting Waveform Graph
I designed a programme that will show an ECG signal from txt file in a waveform graph. But when I press the start button, the graph looks like "Original".png.
But when I tried the same programme on others computers, the graphs shows perfectly fine. as you can see "later".jpg
I have reinstalled LabVIEW thinking there might be some problem. but it's not what should I do?
OriginalOriginalLaterLater
(1,799 Views)
This could be anything.
Is the data exactly the same?
(1,750 Views)
Attach the data file and let us see what it looks like (to us).  Why do you have two different data files and two different plots in your "example" program?  Aren't you saying that a single program gives you different outputs on different PCs?  Send us the single program and the single data file, please.
(1,713 Views)
The graphs look identical other than they're looking at a different range for the y-axis.  Have you right-clicked and tried looking at the settings for that axis in "original"?
(1,709 Views)
