Problems with Mouse Down event for a picture control embedded in tab.
I noticed that when trying to get a Mouse Down event for a picture control that the Mouse Down will not be 'fired' if the picture is embedded in a tab control. It also appears that this problem exists for other controls (I only tested a slider in addition to the picture). It isn't much of an issue for me now as I can just poll the mouse property of the picture control, but the Mouse Down event has information that I may want access to in my next software revision (button pressed, and Alt mod). I could do that by handling the Mouse Down event for the tab itself and checking to see if the the mouse property isn't -1, -1 for the picture, but that seems a little bit too kludgy (sp?) to me and wouldn
't address the issue with other control types. Any chance of this being addressed by a patch sometime in the next couple of months???
(3,097 Views)
Hi Tuck,
This is devistating! Your example demonstrates the issue well on the machine I am using.
I have NI support looking into this issue as I write.
Service request # 468881.
As soon as I hear more I will share.
Thank you for sharing this example.
Ben
(3,097 Views)
This "feature" has been confirmed by NI.
I will post more when I am able.
Ben
(3,097 Views)
I am having the same problem, any chance there is an answer to this problem yet (since it is now 8/2004)?!?
(3,097 Views)
The problem I reported above was in LV 6.1.
As a work-around, I used the mouse down on the tab control and did the math to decide if the picture was clicked.
I have been told that this was fixed in LV 7.0. I can not confirm.
You could call NI and ask about the service request number I cited above.
I hope this helps,
Ben
(3,097 Views)
