Problems with DAQ property Node Installation
I have a problem where when hover the mouse over a DAQ property node or click to select change property on the node I don't get any settings for the node at all, it just has no properties greyout. If I try this on another computer the node properties are all there for my VI. There must be something wrong with my Labview 11 DAQ installation. I tried reinstalling all the latest updates for V11 including the latest DAQ drivers still the properties are missing. As said, it just this computer, the other is fine. Does anyone know what I can do further versus having to reinstall the entire Labview environment again. I hope I don't have too.
Tnx.
(2,859 Views)
Hi QRP,
This is quite a strange issue, and unfortunatly, I believe the easiest solution to this would be a reinstall of LabVIEW and DAQmx.
When you reinstall LabVIEW, the best course of action is to uninstall all NI related software (DAQmx and LabVIEW) and then reinstall on a clean system.
You might be successful with just doing a repair install, but the probability of success of a full reinstall is much greater.
Please refer to the following document on how to uninstall NI software:
http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D?OpenDocument
Staff Certification Engineer
(2,822 Views)
Hi QRP,
Before taking the time to reinstall, check the property filter setting described in Missing Properties in DAQmx Property Nodes.
Brad
Brad Keryan
NI R&D
(2,810 Views)
