Problems on building a DLL with 2D array input
Hi everybody,
I am trying to build a DLL that has in input a 2D array of doubles, anything seems to work fine and the DLL is created. Unfortunately there's no way to use it inside another vi: it crashes LV.
I developed others DLL that pass different kind of data, but not arrays in input.
I attach here a simple example that shows how I am trying to build and use the DLL.
- Could anybody tell me what is wrong in it? ( Watch-out; the exec-Dll.vi crashes LV when executed!)
- If I change the calling conventions to StdCall, could I use this Dll in Visual Basic, or Visual C?
Thanks a lot in advance
(2,941 Views)
You have to supply the C/C++ source for the DLL. Can't find your problem otherwise, but I guess you are dereferencing the handle a bit wrong.
(2,941 Views)
Andalu;
I think in your function prototype, it should say "TD1Hdl arrayIN" instead of "TD1Hdl *arrayIN".
The following example is an excellent reference:
Passing a Variety of Data Types from DLL to LabVIEW
Best regards;
Enrique
www.vartortech.com
(2,941 Views)
