Problems installing App Builder
Hi I just got a new computer and naturally wanted to install LabView 6 on it. LabView 6.0 installed just fine and the updater to version 6.02 also worked as it should. However when I try to install the App Builder it crashes in while copying the files (looks like it's almost done). It stops responding and a process called msiexec.exe along with LSASS.exe takes all my CPU cycles. When I try to run the App Builder I get two 1003 errors with the same error message "Error 1003 occurred at Open VI Reference in Dist Call Get Icons.vi....." Anybody know what I need to do get App Builder installed properly?? My system is a brand new Dell P4 2GHz machine running Win2K SP2.
Jacob Thastrup
(2,703 Views)
don't know if its relevant, but I've had problems installing loads of NI
stuff on Dell machines recently - I think the CD-ROM dirve is just too fast
or too sensitive to slight flaws in the media. I've tended to actually copy
the files to a temp directory on a hard drive and installed from there.So
far this has worked in 100% of cases.
All the best
Andy
"jact" wrote in message
news:506500000008000000B6300000-1004225886000@exchange.ni.com...
> Thanks
> Jacob Thastrup
(2,703 Views)
