I can't get what you said. The problem is still not solved. I run the formula.vi alone ,it seems that there is no wrong .But when we run the BYSJ.vi,the formula.vi seems wrong
for example , I set the #sample =300,the the x,dx should be 300 points ,the cofficent is 6 points ,the I is 300 points ,but the result is not like I expect
what is the reason ? the subvi(formula.vi) is something wrong ? but i dont know where !
thanks
As a man you should be ....
