Problems about the nonlinear least squares
Refresh508,
you will find that everything works much better when the coefficients and X array are fed at the right position in the formula vi : the inputs have been inverted, with regard to their use in the XuNon-linear Lev-Mar fit vi.
Hope this equilibrate my previous post, Christian ?
CC
Chilly Charly    (aka CC)
Message 11 of 16
(947 Views)
Good catch, CC! The world is back in balance. 🙂
Message 12 of 16
(910 Views)
I can't get what you said. The problem is still not solved. I run the formula.vi alone ,it seems that there is no wrong .But when we run the BYSJ.vi,the formula.vi seems wrong
for example , I set the #sample =300,the the x,dx should be 300 points ,the cofficent is 6 points ,the I is 300 points ,but the result is not like I expect
what is the reason ? the subvi(formula.vi) is something wrong ? but i dont know where !
thanks
As a man you should be ....
Message 13 of 16
(882 Views)
Yes, there is something wrong!
Your formula VI has the inputs reversed! Inside the Xufit VIs, the upper left terminal is for the coefficents and the lower left terminal is for the x-arrays. In your formula VI the upper left terminal is for the x-arrays and the lower terminal is for the coefficients.
You need to switch these two connectors in your formula VI and swap the wire leading to it in your main VI. Now it works just fine!
See attached (LabVIEW 7.0).
Message 14 of 16
(872 Views)
Altenchment:
Thank you very much for your helping ,this problem is solved. I just have been being learning Labview for about two months ,so I will meet many problems . If the problem I cant work it out ,I will ask you ,CC.
Message 15 of 16
(847 Views)
Thanks for your helping last time.This time I met a problem again,as you see when I set the parameters Amplitude=10000 or greater ,then the output will not turn out .
Another problem is the derivative of the output on the waveform wobble after I click run for a while
Message 16 of 16
(919 Views)
