ProblemS to load fuzzy controller in NI myRIO
Dear,
I am designing a fuzzy control system implemented in a NI myRIO controller and at the moment of starting the simulation of the system, it fails to load the file (.fs) where the technique is stored. LabVIEW throws me the code 7 error. I tried to fix it in different ways, but I couldn’t.
As for the examples' files, these do load me without problem in the simulations.
What can be the origin of this problem?.
I hope you can help me.
Thank you very much.
Message 1 of 8
(2,311 Views)
Estimados,
Me encuentro diseñando un sistema de control difuso implementado en un controlador NI myRIO y al momento de iniciar la simulación del sistema, este no logra cargar el archivo .fs en donde se encuentra guardada la técnica. LabVIEW me arroja el error code 7. He intentado solucionarlo de diferentes formas, pero no he podido.
En cuanto a los archivos de los ejemplos, estos si me cargan sin problema en las simulaciones.
Cual puede ser el origen de este problema?
Desde ya muchas gracias
Message 2 of 8
(2,308 Views)
Hi deco,
@deco1234 wrote
It fails to load the file (.fs) where the technique is stored.
The most common problem for new RIO users is: they forget (or don't know yet) the RIO is a computer of its own! That RIO device cannot access the harddrive of your development computer! You have to transfer any files to the RIO device when deploying your program...
Btw don't start multiple threads for the same topic! And there is a Spanish regional board for non-English discussions...
Message 3 of 8
(2,300 Views)
In addition to GerdW's Wise Words, showing us a picture of an Error Message only says "You did something wrong" (but Gerd picked up on the Glaring Mistake you made).  What we really need to see (particularly when the error is more subtle) is your LabVIEW Code, the actual VIs (or the entire LabVIEW Project, compressed into a .ZIP file) (and, please, no "pictures" of code).
Message 4 of 8
(2,259 Views)
Thank you very much for your answer. How can i fix the problem?
How do I add a file to the RIO? and how do I load it from the VI to make it work?
I tried but it didn’t work.
Kind regards
Message 5 of 8
(2,238 Views)
Hi deco,
You need to create a BuildSpec to create an RTEXE (with all data files attached) and deploy it to your RIO device - as is explained in the RIO beginner tutorials…
Message 6 of 8
(2,230 Views)
Thank you very much again. Where can i find that beginner tutorial?
kind regards
Message 7 of 8
(2,220 Views)
Hi deco,
When I use "LabVIEW RIO beginner guide" with my favourite web search I find a lot of interesting resources. I recommend those from NI...
Message 8 of 8
(2,211 Views)
