Problem within program
I am trying to build a coke machine which dispenses coke and fanta. However, whenever I insert the coins into the machine, it only dispenses out coke only.
I feel like I am making an assumption somewhere, but I am unaware where that might be. Can somewhat take a look and give me a few intakes?
(3,822 Views)
None of your state decides to switch to "Dispense Fanta"  then how your program will switch to "Dispense Fanta"
Recheck your code
(3,781 Views)
Boolean buttons COKE and FANTA events are not connected/used in any states to decide which to dispense.
First make your requirement in a flow diagram and proceed with your implementation, problem in your design itself.
(3,779 Views)
Can you help walk me through this? I'm kinda lost.
(3,773 Views)
Accepted by Seacreature2002
As PalanivelT stated, you really need to document what you want your application to do first.  Make a state diagram chart showing how the states transition.  Once you get that, then you can step through each state and make sure they are doing what they are supposed to.
(3,762 Views)
