12-10-2012 10:18 PM
Hi all,
I have designed status bar for my UI using splitter bars as:
The problem is when I open the same UI on a different monitor, the status bar becomes weird as:
I think since I have checked for "maintain proportions of window for different monitor resolutions",this problem is occuring.But that feature is required for other objects which are placed on the main panel of UI.
Is there any way to resolve this problem?
12-10-2012 11:50 PM
Hi
i am not sure if this will work but suggest you to tru Locking the splitter bar. also, if you want some controls and indciators which are to retain their size even the panel size changes, then, select those controls and indicators, group them and then lock them using the Reorder tool set on teh Front panel.
12-14-2012 02:56 AM
Hi
any update? did it work?
12-15-2012 07:36 AM
I changed the splitter sizing to "splitter sizes proportionally" and then locked all subpanels. It worked! ![]()
