Problem with status bar
Hi all,
I have designed status bar for my UI using splitter bars as:
The problem is when I open the same UI on a different monitor, the status bar becomes weird as:
I think since I have checked for "maintain proportions of window for different monitor resolutions",this problem is occuring.But that feature is required for other objects which are placed on the main panel of UI.
Is there any way to resolve this problem?
(2,744 Views)
Hi
i am not sure if this will work but suggest you to tru Locking the splitter bar. also, if you want some controls and indciators which are to retain their size even the panel size changes, then, select those controls and indicators, group them and then lock them using the Reorder tool set on teh Front panel.
Freelance_LV
TestAutomation Consultant
(2,729 Views)
Hi
any update? did it work?
Freelance_LV
(2,684 Views)
I changed the splitter sizing to "splitter sizes proportionally" and then locked all subpanels. It worked! Smiley Happy
(2,661 Views)
