Problem with serial port
Referring to the point about the error message - I already had error codes without message, although everything is installed. God alone might know why it did not work Smiley Wink.
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 11 of 13
(709 Views)
My vi is work when I use a computer that install DAQ......  T_T ,Oh God.
Message 12 of 13
(692 Views)
The GPIB and VISA VIs are shipped with LabVIEW, but you will not have support for them (they will not work) until you install NI-488.2 and NI-VISA. These should be the only driver VIs that are built into LabVIEW.
Missy S.
Project Engineer
RoviSys
Message 13 of 13
(666 Views)
