Problem with list folder
 Hi
 I am trying to use List Folder to list out all the LVM file in the folder. However , i am getting this error message when i run the VI.
 I have tried to key in the pattern as *.lvm or even using loop, this error message still pop out. Please help me.
Cheers
PX
(4,095 Views)
Accepted by pengxin
Hi PX,
I guess you need to input a folder instead of an LVM file path.
Hope this helps,
Mavis
(4,080 Views)
Hi
Previously i am using a control to direct my path, so that it force me to choose a file.
Now i have changed to use constant and type in the path name of the folder and problem solved.
Thank you Marvis
Cheers
PX
(4,073 Views)
Perhaps you should mark Mavis's post as the solution to your problem rather than your own thank you message.  First you will have to go to the options menu on your message to Unmark it as the solution.
(4,057 Views)
Also, a control does not 'force' you to choose a file. Right click and select 'Browse Options'. Change the selection mode.
(4,052 Views)
Thank you Raven and Dennis
I have changed the accepted solution to Marvis Thread. And under the browse option i have noticed the selection mode, i did not know beforehand i can do this.
Thank you guys
Cheers
 PX
(4,041 Views)
