Problem with linear chart
Hello.
After two days tray to solve problem, I need your help.
I have problem with presentation some data. Data growning aproxx. linear. I read this data from device. Sometime my .vi not successful read data and in this case my chart have sags to zero (see on picture)
http://prntscr.com/6yq9y2
How I can make chart :  if not succesfull read data use previous value to show on the graph? In this case I not have big sags to zero.
Pls help.
(3,846 Views)
Hi Qooler,
easy solution: when you don't want those zeros in your chart you shouldn't put them into the chart plot!
Some pseudocode:
new value := readDAQ()
IF error on reading new data THEN
  new value := old value
ENDIF
plot(new value)
old value := new value
Please attach images/VIs/files directly in the forum using the attachment button right below the message edit box. Using 3rd party websites will just lead to problems when accessing this website from behind (company) firewalls!
(3,832 Views)
Accepted by Qooler
Another option would be to replace the 0 with NaN, this would produce a gap in the display that would communicate that a data point was missing.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,808 Views)
Mike,
How I can use NaN for this simple graph. Thee random numeric plot to graph. If random number 0 use NaN? (this is same case like my problem when read data from device)
http://prntscr.com/6z1n74
(3,791 Views)
Accepted by Qooler
Hi Qooler,
again: PLEASE DO NOT POST LINKS TO 3RD PARTY WEBSITES! Attach images directly in this forum!
Yours: img.png(Using AutoClenaup would be nice before posting images…)
(3,782 Views)
The question is why the 0 is happening in the first place. The preferred method would be to detect that cause and use it to trigger the substitution .
Mike...
LabVIEW Champion
(3,763 Views)
