Problem with installing NI IMAQ for USB
Hi
i am trying to install "NI IMAQ for USB" on my computer, but the installer always shows the error message "You must have Vision 7.1 or higher with LabVIEW 7.0 or higher, or you must have Vision Assistant 7.1 or higher to use this add-on" even though there is LabView 7.1 and Vision already installed.
Can someone help me to solve this problem??
Thanks in advance!
Sebastian
(2,976 Views)
Hello Sebastian.
Before installing IMAQ for USB, you MUST install ni-vision 7.1.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,968 Views)
Hello Alipio
thanks for yor answer.
My company bought the NI IMAQ for IEEE 1394 and this is working with the installed LabVIEW environment.
I am wondering why then the USB version doesnt work.
Is it really necessary to buy the whole Vision Development Kit to run the USB version?
Thanks for your help
Sebastian
(2,963 Views)
Hi Sebastian,
The answer is YES, you need VISION SW to use this driver.
Like mentioned on the download page of the USB IMAQ driver you need this system requirements to use this driver:
- Windows 2000/XP
- LabVIEW 7.0 or higher with NI Vision 7.1 or higher for the USB LabVIEW support.
- Vision Assistant 7.1 or higher for the USB Vision Assistant plugin module.
There are some other ways you can try. Check this KB:
http://digital.ni.com/public.nsf/allkb/274A74A901399D0486256F32007295F9
Luca
Luca
(2,940 Views)
