Problem with formula node
I am using LabVIEW 2012 and there seems to be a problem with the formula node. The output of a simple not operation is not correct.
I have a U8 input whose value is 255. I apply a not operation(a = ~a;) and value returned by the formula node is also 255.
Is it a bug in the node or is there some other way to compute bitwise NOT?
Ritesh
(2,918 Views)
Accepted by topic author LVCoder
You need to use the Exclusive OR function.  So what you really need is:
a = a^0xFF
 EDIT:  Digging some more, it is called a "bit complement".  I would consider this a bug.  I'm seeing the same with 2011.
(2,913 Views)
