Problem with formula node &&
Hi, what I´m trying to do is when my capacitive sensor and my inductive sensor detect and object (they give a value of 1) I want the counter of metalic objects count (the one next to the blue led), but i doesn´t, it´s like the && is not working, the indicador for cnm is the only working (when both sensors detect the indicador next to the green led count, but it shouldn´t). Anyone know why this is happening?
(1,677 Views)
I would suggest learning and implementing the same code in LabVIEW.
Santhosh
Soliton Technologies
(1,651 Views)
don't do this
instead of local variables,
use a shift register
(1,636 Views)
