Problem with driver for Thermotron 8800 in LabVIEW 8.0
Hi everybody!
File :TH8800.dll" can use for communication GPIB, RS232, TCP/IP?
Best regards
Van Phu
Message 11 of 17
(3,118 Views)
Hi
I am new using Labview and I am having problems converting the files I downloaded from Thermotron
8800-8200 LabVIEW 8.x Driver (2.48MB ZIP File)
The email I got back from a engineer at Thermotron is pasted below
Yes, the VIs need to be converted.
Per the "Converting VIs" section on page three of the attached NI manual the conversion should be automatic when the VIs are loaded.
I tried what they indicated, but the files do not work with labview 2009 or higher
Can someone help me out maybe post a converted set of files so I can get started?
Message 12 of 17
(3,037 Views)
You did not attach any files to be converted and in any case, the correct place to post this request is to the upconvert thread that you see noted at the top of the page under Announcements.
Message 13 of 17
(3,027 Views)
Hi
Has anyone had luck to control the thermotron 8200 chamber?
Message 14 of 17
(2,942 Views)
I basically wrote a standalone VI application that can detects and replicates most of the basic functions on the thermotron touch panel. It is very simple by referring to the thermotron user manual and send the command thru tcp protocol vi library.
Take a look at the details of the complete project and snapshot below: (Vote for me if you think it's cool!)
https://decibel.ni.com/content/docs/DOC-18615
Message 15 of 17
(2,851 Views)
Are you done spamming these forums?
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/thermotron/m-p/2048534#M54337
http://forums.ni.com/t5/LabVIEW/thermotron/m-p/2048530#M668229
http://forums.ni.com/t5/LabVIEW/Thermotron-TCP-IP-interface/m-p/2048526#M668227
http://forums.ni.com/t5/LabVIEW/Controlling-Thermotron-Basic-steps/m-p/2048524#M668226
http://forums.ni.com/t5/LabVIEW/Problem-with-driver-for-Thermotron-8800-in-LabVIEW-8-0/m-p/2048512#M...
Message 16 of 17
(2,847 Views)
Apologize for the spam, I do tried with tcp/ip and it works with LV 10. Sharing attached student-level created subVIs for Thermotron 8200. :smileyhappy:
Message 17 of 17
(2,828 Views)
