Problem with continuos sound input
Hi, I'm trying the continuous sound input example in labview, my problem is that whenever I try to run the VI the graphic of the sound acquired is empty, I just get a flat line with value 0. I even tried to use an external microphone but the problem persists. Does anyone have any suggestion? Thank you
(1,897 Views)
Hi depa,
Do you get any errors while acquiring sound data? (Might be a problem with sound drivers.)
Or does the VI run without any errors and just outputs waveforms consisting of just "zero" values? (Might be a problem of the mic or the sound input circuitry of your computer.)
(1,875 Views)
I get no errors, the VI runs correctly but nothing is displayed on the graph, just a flat line at 0
(1,863 Views)
Hi depa,
so test the mic using other software (like e.g. Audacity).
Please also check you are using the correct sound device in case of multiple mics!
(1,852 Views)
Hi, thanks for the suggestion, I just tried with audacity and everything works fine, it seems that the problem is only with labview. I really don't know how to deal with the issue.
(1,849 Views)
Hi depa,
Me neither as I cannot test with your computer...
(1,847 Views)
I tried with the 2019 version of labview and it's now working
(1,832 Views)
