Problem with Plot Starting at Zero Seconds.vi
In document with ID: 4KTFBLE9 an example vi is offered.  Its name is "Plot Starting at Zero Seconds.vi".  I have problems in "borrowing" the function labeled "Waveform Chart", comprising a box with the text "XScale Multiplier".  When I transfer this function to another vi, the function is transmutated to another function.  What happens, and what am I doing wrong?
(2,280 Views)
This is a property node and it will only link directly to items in the same VI. If you move it to a different VI, it will turn into a plain property node.
  • If you have another waveform chanrt in the other VI, you can right-click the copied proeprty node and select "link to..." and select the local waveform chart.
  • If you want it to act on the "other" wavform chart, you need to make the second VI a subVI and wire the reference to it via a connector.
  • If you want to create a new such property node, simply right-click the waveform chart and select the desired property.
Message Edited by altenbach on 11-18-2008 08:51 AM
(2,277 Views)
