Intel LPC
I want to test a circuit card that has an Intel LPC interface.  Can I use a NI FPGA module/card to perform the interface function?  Which card/module would be best?  I have a PXI chassis, so a PXI card seems obvious, but I could go with a CompactRIO solution also.
(2,744 Views)
Can you provide more information on the LPC interface.  For example:
  • connector or cable and # of pins (input and output)
  • voltage levels, impedance
  • clock & data rates
  • clock sources
This will help determine the optimal solution.
(2,739 Views)
We have a 7 pin interface running from the 33MHz PCI clock.
Standard Intel LPC interface.
(2,735 Views)
