Problem with ON color for Buttons
hi
my front panel has two buttons and I have set different colors for ON color property (green and yellow). However,
when a button is pressed, it is highlighted in color set for the other button.
(2,893 Views)
Any suggestion.....
(2,875 Views)
Hi Nustian,
at first: it is considered "rude" to bump a thread after less than 2 hours. We are just volunteers (atleast most of us)…
Second: you should attach a VI or atleast snippets to demonstrate your problem.
How should we know what you have set your buttons, how did you set their properties and what went wrong this way?
(2,871 Views)
at first: it is considered "rude" to bump a thread after less than 2 hours. We are just volunteers (atleast most of us)…  Noted
I am simply setting the color property through property pages, the colors are not set programmatically
(2,851 Views)
Why don't you exchange the buttons, when the colors appear on the wrong button? 😉
What happens when you redefine the colors for each button?
(2,841 Views)
