Problem with MultiplyArrayElements and U64
Hello folks,
after using LV8 for 1 day I found the first bug...
When using the "Multiply Array Elements" with an U64-array LabView8.0 crashes... Sometimes I get a message "Labview.exe has generated an error...", sometimes LV8 closes silently.
Using the same operation on I32-arrays works perfectly...
Message 1 of 10
(6,026 Views)
And yes, I already submitted a request to the NI engineers...
Message 2 of 10
(6,014 Views)
Interesting. For what it's worth I was able to confirm this. Running 7.1/8.0 on XP SP2.
Message 3 of 10
(6,006 Views)
HI!
As soon as I read this thread I went quickly to make my LabVIEW fail, but I found out that LabVIEW 7.0 has no U64 numbers Smiley Sad Do you know in which version the U64 was added?
Regards.
Robst - CLD
Using LabVIEW since version 7.0
Message 4 of 10
(5,996 Views)
@Robst wrote:
HI!
Regards.
I wouldn't go rushing to make LV fail. There are enough problems with it without trying to crash it.
64 bit integer support was added in LV 8.0.
___________________
Try to take over the world!
Message 5 of 10
(5,989 Views)
I was just trying to check if I could reproduce the error in my LabVIEW, just to check if it was a version problem or something like that. I don't go around the world trying to make LabVIEW fail, as you may think. No LabVIEW programmer wants LabVIEW to fail, I guess.
Regards.
Robst - CLD
Message 6 of 10
(5,971 Views)
Hello GerdW,
The behavior has been reported to R&D (# [ID:3U276JUL]) for further investigation.
Thanks for the feedback!
Best Regards,
Volker
Message 7 of 10
(5,917 Views)
Hello to all,
for those interested:
The problem is found and will be solved with the first update patch (LV8.0.1).
Message 8 of 10
(5,912 Views)
GerdW must have been close to somebody on the "inside" Smiley Wink.  This was reported to R&D (# 3U276JUL) and was fixed in LabVIEW 8.0.1. Here is a link to the LabVIEW 8.0.1 maintenance release and here is a link to the current evaluation software download for LabVIEW.
Thanks!
Travis H.
LabVIEW R&D
Message 9 of 10
(5,662 Views)
Hi Travis,
well, I got an answer from the German LV support... After this I made a message to the forum to let other people know about this topic.
Message 10 of 10
(5,656 Views)
