Problem with INF
I am with a problem regarding the calculation of capacitator reactance (XC=1/WC), i have a problem when my capacitator is 0 ( i can adjust the value with a knob) the display number will be INF, because i am dividing for 0.
Is there a way to display 0 when this happens?
When capacitator is 0 i want to display that my XC is also 0 and it keeps displaying INF.
Thanks in advance,
Montjack
Message 1 of 9
(6,282 Views)
Just check for zero and conditionally substitute a different code path. Can you show us your code?
Message 2 of 9
(6,257 Views)
I was able to switch the maximum to display at max 16 bits (32768), even tho it wont display INF, but it will display the 32768, which doesnt solve at all my problem.
The problem is that by showing the max number it will affect all my program, that is why i need to fix this issue.
Montjack
Message 3 of 9
(6,252 Views)
Hi Montjack,
IF divisor == 0 THEN
  result := 0
ELSE
  result := dividend/divisor
ENDIF
Have you tried to implement this simple algorithm in LabVIEW?
Message 4 of 9
(6,242 Views)
You could also just set the input range of the knob such that zero is not allowed.
Message 5 of 9
(6,235 Views)
Accepted by Montjack
Hi Montjack,
please post your questions here in the forum, using PMs isn't the right way!
Why do you use FXP datatype as shown in your PM?
I give you a hint on how to implement the algorithm:
Btw. to calculate the reciprocal you could find a specialized function called reciprocal… 😄
Message 6 of 9
(6,232 Views)
Thank you for the help, i managed to do it 🙂
Message 7 of 9
(6,221 Views)
What's the point of the weird output configuration? Just keep it all DBL!
Message 8 of 9
(6,217 Views)
It was when i was trying different data types 🙂 I will change, Thank you 🙂
Message 9 of 9
(6,213 Views)
