Problem with Graph scales
      I have a graph with 3 y axes, named sig 1,sig2 and sig 3. The problem is i need to have sig 2 and sig 3 to be in one scale, so is there a way to do it.
(2,741 Views)
If you want to display sig 2 and sig 3 on the same scale you only need two Y-Axes.
Delete the 3rd unnecessary Y-axis 'sig3' and rename the Y-Axis labelled 'sig2' to 'sig 2&3'
Go into the graph properties and select 'Plots'
Select plot 'sig2' from the pull down at the top and ensure that the Y-Axis pull down near the bottom is set to 'sig2&3'
repeat for 'sig3' ensuring that the Y-Axis pull down at the bottom is also set to 'sig2&3'
Senior Software Engineer
www.Adansor.com
(2,721 Views)
HI,
      Thank you, I have also tried that. My main problem is that i don't to show the scale of sig 3 but it has to be present for plotting purpose. I just want to make scale of sig 3 invisble but not the name of sig3 .
(2,718 Views)
