Indicating a variable value change on the front panel (event? signal? queue?)
I have a subvi which performs a measurement in a loop, and I would like to update the front panel of my main VI each time the measrement is performed.  How do i generate an event when this variable is written to/changes value?  the variable being written to is global, but I can't get the front panel of the main VI to update without polling, which distatesteful.
(2,407 Views)
If I'm sending data back up to a GUI from a subVI, I like to use User Events.  I don't recommend using a global variable.  You can send the data in the event.
If you open the LabVIEW Example Finder (Help->Find Examples...) and search "user events" there is a fairly old example that should be able to explain the details.
GCentral
(2,405 Views)
