Problem with Graph's 'Export Image' procedure
The error still occures.
Usually never, when I use the "Highlight Execution" function, though...
Is it possible that there is a malfuction with the file access granted by WinXP.
Message 11 of 19
(3,968 Views)
Hi Heinrich,
is it possible that you want to write the images to fast? Do you have, like I, a "Wait" inside the loops?
Do you only get the Error-Message which we have created in the loop or do you also get a popup message like this: "Error saving image to disk"?
Have you ever tried to delete the "old" image before creating the new one? If you haven't tried it, please implement this into your code just to be sure.
Schilli
Message 12 of 19
(3,961 Views)
I copied the loops completly, including the "waits".
I also added a delete.
Is is possible that the pictures aren't created, if the VIs Frontpanel is not loaded ?
I tried several times, after I changed the SubVI-Call, so that the VI's Frontpanel is actually shown. That is not what I want, but since then, the pictures always were created....
Message 13 of 19
(3,950 Views)
Hi Heinrich,
could you please add a picture of an exported image when it fails to export.
Yes, it is possible that the image isn't created when you only let it run as an SubVI, but then you should at least become a new image without any graph data, but with your axis shown.
You can try to add a wait in the second part of the sequence diagram, lets say 500ms or greater and try it again.
 Please let me know if it works if you do integrate the wait.
Message 14 of 19
(3,945 Views)
In this case, there is no file.
Nope. No picture at all.
> you can try to add a wait in the second part of the sequence diagram, lets say 500ms or greater and try it again.
I did that, but nothing changes. Actually 'file info' after the drawing procedure created an 'file not found' error.
So, there seems to be no file written at all, unless the VI is opend, when called.
I think, that's what I have to live with...
regards,
Heinrich
Message 15 of 19
(3,929 Views)
Hi Heinrich,
I found a workaround which solves your problem.
You have to change some VI-properties of your SubVI in which you will create the pictures.
Inside the VI-properties choose the category "Window Appearance" and just click on "Customize". A new popup window will open in which you can check "Show front panel when called" and "Close afterwards if originally closed". If you have checked them just press OK.
Then choose the category " Window Run-Time Position" and select at the Position drop down menu "Minimized".
Now press the OK-Button and save your SubVI.
Now everytime you SubVI is called it will open in a minimized window which will be closed when the images are written.
regards
Message 16 of 19
(3,922 Views)
Accepted by Heinrich Krebs
Message 17 of 19
(3,919 Views)
Hi Heinrich,
here is just another possible solution for your problem.
In this vi I just use "Get image" instead of "Export Graph". Just have a look on it and maybe do it that way.
regards
Schilli
Message 18 of 19
(3,911 Views)
I'm sticking to the workaround.
The alternative generates images that look screen elements, not just a plain diagramm. That is not printer friendly and changing all the color is too much trouble...
Message 19 of 19
(3,898 Views)
