Problem with Generating Analog Output in 7851R FPGA Card
Hi all
First of all i am a begginer in FPGA programming.
In my application, I am generating some analog voltage, for example 6V in a 7851R FPGA card which is placed in PXI 1033. I am passing this voltage to another PXI having LabVIEW RT. Instead of getting a continous 6V i am getting some spikes having 6V. I am attaching the screenshot of  waveform that obtained in PXI having RT. The PXI card used is PXI 4462. I am also attaching the code. Why i am getting this spikes? Is there any other procedure to generate a continous signal? Is there any problem in acquistion part?
Please help me
Thanks & Regards
Rajesh R. Nair
Rajesh Raghavan Nair
Certified LabVIEW Architect
Certified Teststand Architect
(3,040 Views)
Try removing the Loop Timer and compile the FPGA again.
(2,913 Views)
Accepted by topic author Rajesh_Nair
Thank You Sumit.
Problem is solved!
(2,908 Views)
