Problem with Generating Analog Output in 7851R FPGA Card
Hi all
First of all i am a begginer in FPGA programming.
In my application, I am generating some analog voltage, for example 6V in a 7851R FPGA card which is placed in PXI 1033. I am passing this voltage to another PXI having LabVIEW RT. Instead of getting a continous 6V i am getting some spikes having 6V. I am attaching the screenshot of  waveform that obtained in PXI having RT. The PXI card used is PXI 4462. I am also attaching the code. Why i am getting this spikes? Is there any other procedure to generate a continous signal? Is there any problem in acquistion part?
Please help me
Thanks & Regards
Rajesh R. Nair
Rajesh Raghavan Nair
Certified LabVIEW Architect
Certified Teststand Architect
(3,028 Views)
Try removing the Loop Timer and compile the FPGA again.
(2,901 Views)
Accepted by Rajesh_Nair
Thank You Sumit.
Problem is solved!
(2,896 Views)
