Problem with Floating point numbers
Hi, i am using the Community Version for MacOS 14.4 (M1 Mac). When I create a DBL Numeric Constant and I Enter a value, for example 1,5 or 1.5 and I press Enter or click out of the Constant, the Value just changes to 1. Also when I Create a Numeric Control (Representation set to Double) and I try to set the Increment to 0.5 it does the same thing and just lets me set it to Integers. I just can't enter anything after the ".".
My System language is German and the Community Version is in English so maybe it has something to do with that.
I appreciate your Help.
(2,081 Views)
I have the same Problem. I am using the Community Version for Mac OS. When I create a DBL Numeric Constant I can enter 1.5 or 1,5 for example but the Constant changes to 1 as soon as I hit enter.
(2,069 Views)
And what is their Display Format? (you can find it in the Control properties or right-clicking on the constant)
Paolo
(2,068 Views)
Is it orange? If it's blue it's an integer, then you need to r-click and change representation to Dbl. If it's a front panel object it's properties might be set to minimum step 1 and coerce to nearest.
Qestit Systems
Certified-LabVIEW-Developer
(2,052 Views)
I installed the Q3 Patch and now it is working.
(2,028 Views)
Hi. I'm experiencing the same problem with decimal numbers when using Numeric Contants and Numeric Controls/Indicators.
I downloaded the Labview CE 2023 Q3 patch on my Mac, but it only containts an HTTP Drivers file plus an Extras and a Licences, Patents & Copywrites folder.
Can you explain what you did?
(1,825 Views)
Sorry, I'm officially blind.
The patch was right in the corner.
Installed it, and now it works!
Thanks! You spared me a lot of trouble.
(1,813 Views)
