Developing cRIO application without hardware (Not FPGA)
I wish to build an application/get started before my hardware arrives (~1.5 months from now).
I am using the following:
  • cRIO-9047 Chassis 1.6 GHz Quad-Core, 70T FPGA, RT, 8-Slot, XT
  • NI 9209 +/- 10V Analog Input, 500 S/s, 16Ch Module
  • NI 9227 4 ch current input, 5Amp, ISO, 50k, 24bit
  • NI 9217 4-Ch PT100 RTD 24-bit, 100S/s/ch, Analog Input
    Module
  • NI 9478 16-Ch 0V to 50V, 1.2A per ch, 7 us, Sinking DO
    Module
This project is for sending current through devices using the sinking DO module and monitoring these devices.
I couldn't see how to simulate the hardware in NI MAX. I understand that its not going to be possible to simulate the FPGA controller, but shouldn't I be able to simulate Labview real time OS that the Chassis could run?
I do plan on using FPGA eventually for a PID controller to simulate constant current instead of voltage. But for right now, I just want to simulate labview realtime, that way I can start building the realTime OS (cRIO) part of the application right away.
(1,037 Views)
Accepted by topic author eli.barber
You could simulate a cDAQ chassis and use DAQmx to simulate your cRIO IO and you can build your control logic around that.
(1,018 Views)
Thank you!
(1,005 Views)
