Problem with DWDT Comparison
Hi all
I noticed that the DWDT comparison vi's does not compare all of the bits in a digital file when making an evaluation.  If you have two different digital signals of different sizes, the vi only compares the first n bits, where n is the number of bits in the shorter signal.
For example, see the attached LV 2009 vi.
Regards
(2,536 Views)
Hi tmaxprt,
That is expected behavior. One can only compare elements up to the minimum number of the two.
Jeff | LabVIEW Software Engineer
(2,520 Views)
