Problem with Contour Move in Softmotion
I got the 3 motors in SolidWorks , my table looks lika that:      40  50  60 , cordinate space consist of 3 axis and when i try to change on Active Mode an error occurs:
        50  70  80
        70  90  100
        90  95  110
"An error occurred while attempting to switch the I/O scan mode. NI SoftMotion: The size of the buffer or array is incorrect."
Any idea why ?
Bartek
(3,914 Views)
Hi Bartek,
Did you see this topic?
http://forums.ni.com/t5/LabVIEW/NI-Softmotion-problem-Size-of-the-buffer-or-array-is-incorrect/td-p/...
Please let me know if it helps.
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(3,810 Views)
unfortunately, it didn't help
below is the link with photos of my Block Diagram:
http://www.iv.pl/images/20379110010119321835.jpg
Greet
(3,760 Views)
Hi Bartek,
SoftMotion only allows you to use tab delimited text files for contour tables, so if you are using any other type of delimiter in your file (such as space), you will receive this error. This will be fixed in the next release of SoftMotion. For an example of an acceptable file, look at the two text files in the following directory: <labview>\examples\motion\FunctionBlocks\Finite Coordinate Contour Move.
(3,706 Views)
Hi Paul,
thanks a lot for the help now it is already working
Best regards
(3,669 Views)
