Problem with Agilent 34970a driver in Labview, cannot perform advanced measurements
I think OPC is good because example works with opc...
Message 11 of 23
(1,821 Views)
Don't be silly. The example READS OPC. It does not set it like you are doing. OPC means operation complete and the whole point of doing a read of it is to give the instrument time to perform the scan before reading the results. Your code has the opposite effect. You set the OPC bit before the operation actually has time to run.
Message 12 of 23
(1,820 Views)
I tried to modify example but example works just for about 10 seconds not longer , then reports error... this is never ending story
Message 13 of 23
(1,814 Views)
Dear Dennis
I have to measure data over atime period.So I thought using the loop is the only option.
Anyways I am attaching my vi here for your reference.
You can tell me if there is any problem with the vi which makes the program run not faster than 5-7 HZ for a single temperature reading.
Also I have tried both RS232 and GPIB but the speeds are the same in both the cases.
Message 14 of 23
(1,795 Views)
Ok this is what worked in my case in the picture
Message 15 of 23
(1,787 Views)
what was the speeds achievable?
Message 16 of 23
(1,779 Views)
I am not sure what do you meen by speeds? I measure only one channel currently
Message 17 of 23
(1,777 Views)
When I mean speed I mean the fastest rate of reading.ie the time lag between one reading at one instant and the next reading of the same channel at the next instant.
Message 18 of 23
(1,766 Views)
Well honestly I did not test what is highest speed I measure 10 HZ, = 10 samples in second during 5 to 10 minutes. That is all I need
I think that User manual says something about max speeds....
Message 19 of 23
(1,737 Views)
siva maybe this can help you there are some labview programs made for 34970a
http://ostarrichi.ch/klaus.ruzicka/klaus/labview/labview.htm
Message 20 of 23
(1,713 Views)
