Problem when working with Write to SpreadSheet
If you use the default separator, it makes no sense to call it a csv file. Excel expects a comma as a separator when you do that. Call it a txt file or explicitly tell Excel to use a tab when you import the file.
Message 11 of 14
(1,347 Views)
I found the solution, it has to do with my Excel region settings (I'm from Chile, Southamerica). The details are on this link: http://feedback.debitoor.com/knowledgebase/articles/248576-when-opening-csv-file-all-data-appears-in...
Thanks for your help.
Message 12 of 14
(1,344 Views)
Agreed. The example given is really a crappy example because it bypasses the array functionality of the spreadsheet VIs. You might as well just write those strings using Write to Text File and just add a line feed each time.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 13 of 14
(1,330 Views)
Glad you got it figured out!
Cheers
Message 14 of 14
(1,328 Views)
