Problem when loading File into PXI 8145RT
I am having some some problem with the PXI 8145 RT.
My application uses the PXI 8145RT and a multifunction DAQ 6031E.
Basically, when I launch the main application on my Host PC, I have to load an Excel file (each line is a test step) first on the Host and then send the all data to the PXI 8145 RT.
Problem is: If this file has more than 357 lines, the application will hang.
It's not a Memery problem since it has 160 MB and the file I m trying to load has only some hundred KB
any idea about what is going on?
Toty
Message 1 of 1
(2,935 Views)
