Problem using in Stacked sequence.
I am using sstacked sequence structure, Where in each sequence I am having a sub VI which will pop up the Front Panel during the sequence, but the sub VI present in the next sequence is also poping the Front Panel. How to avoid this . I want the sub VI present in the next sequence to pop up only after I close the Fornt panel of VI present in the First sequence. Iam using this stacked sequence inside a event structure.
(3,023 Views)
Hi Rajashekar,
do you have some events or while loops where you wait for an user action in your sub vi´s? If you only run through your vi´s and don´t wait on an user action, then the sequence will run through all frames.
Mike
(3,020 Views)
Hi Rajashekar,
Does the first subvi complete all its execution before the second vi front panel appears. If so then it may be that you just need to tell the first vi to close its front panel after it has finished executing. To do this right click on the sub vi and choose 'Subvi Node setup...' then tick the close afterwards if originally closed option
Dave
Message Edited by DavidU on 10-14-2008 09:21 AM
(3,013 Views)
