I'm having trouble setting up VISA serial communication with an instrument (Digi-sense 68900-11 made by Eutech). The communication spec (attached) calls for 9600,8,n,1, XON/XOFF (w/ XON=11 hex and XOFF = 13 hex). I tried this setup and could only get timeouts when I try to read a setting from the controller.
So
then I setup Portmon to watch the OEM's software application (which
works fine). The OEM applicaiton seems to have a different setting for
the "Shake:80" serial setting in Portmon. I've tried a bunch of
different handshake settings using the VISA Serial Setup vi to try and
match the OEM software to no avail. Am I missing something simple?
Also the OEM software seems to
enable a bunch of Serial Events. Some of these I can enable and some I
can't, but when I enable the events the computer justs grinds to a
halt. Do I have to enable and handle the Serial Events or can I ignore
them and just send read and writes? The communication spec makes no mention of using serial events for communication.
Brian
