Problem setting VISA handshaking (cross posted on lavausergroup)
I'm having trouble setting up VISA serial communication with an instrument (Digi-sense 68900-11 made by Eutech).  The communication spec (attached) calls for  9600,8,n,1, XON/XOFF (w/ XON=11 hex and XOFF = 13 hex).  I tried this setup and could only get timeouts when I try to read a setting from the controller.
So then I setup Portmon to watch the OEM's software application (which works fine). The OEM applicaiton seems to have a different setting for the "Shake:80" serial setting in Portmon. I've tried a bunch of different handshake settings using the VISA Serial Setup vi to try and match the OEM software to no avail.  Am I missing something simple?
Also the OEM software seems to enable a bunch of Serial Events. Some of these I can enable and some I can't, but when I enable the events the computer justs grinds to a halt.  Do I have to enable and handle the Serial Events or can I ignore them and just send read and writes?  The communication spec makes no mention of using serial events for communication.
Brian
(3,770 Views)
Thanks for anyone who looked at this.  I found out the problem.  I was missing a portion of the "Header message" when I sent the commands to the controller.  The documentation doesn't really explain this header until you get into the examples.  I missed it in my rush to get things done.  Sorry for the false alarm about handshaking/events/flow control.
Brian
(3,751 Views)
Hi Brian,
I'm glad you found what was wrong. Best of luck in your application. If you hit any more bumps in the road, let us know.
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,741 Views)
Hi Brian,
I am trying to work with this controller too. I wonder if you could share the documentation on communication with the instrument, and maybe your final working code as well.
Much appreciated.
(2,184 Views)
This thread dates to 2006, the last message from Brian was in 2008.
So, good luck.
Paolo
(2,167 Views)
