Problem saving an array using a shift register
In the attached VI I'm building a 1D array of strings, then trying to save it using a shift register. For some reason my data isn't being saved and I dont understand why.
Thank you.
(3,335 Views)
Accepted by topic author chuck72352
You need to wire the array across all empty cases, else it will reset to an empty array whenever such a case occurs.
You also need a shift register on the inner loop.
Message Edited by altenbach on 04-05-2010 02:26 PM
(3,326 Views)
(3,317 Views)
Thank you!
(3,302 Views)
