Problem saving an array using a shift register
In the attached VI I'm building a 1D array of strings, then trying to save it using a shift register. For some reason my data isn't being saved and I dont understand why.
Thank you.
(3,053 Views)
Accepted by chuck72352
You need to wire the array across all empty cases, else it will reset to an empty array whenever such a case occurs.
You also need a shift register on the inner loop.
Message Edited by altenbach on 04-05-2010 02:26 PM
(3,044 Views)
(3,035 Views)
Thank you!
(3,020 Views)
