Problem running more than two analog intputs
Hello all,
I ran into a problem today with DAQmx tasks. I am getting error 20022 "Resource requested by this task has already been reserved by a different task". I got this error when I tried to add a thermocouple DAQMX task in another loop. I am currently reading strain from a NI9219 and volts from a NI9205.
Is there a limit to the amount of analog input tasks you can start on a single chassis?
I've included a screenshot of my devices below. Thanks!!
Message 1 of 8
(4,154 Views)
Accepted by nsievers
According to the product page, you can have 7 taks running.  I am counting 4 on the screenshot you gave.  But if the tasks are running at the same rate, why not just use 1 task and make your life A LOT easier?
GCentral
Message 2 of 8
(4,114 Views)
I can start them from one task even if they are in 2 different loops and sampling at different rates?
Message 3 of 8
(4,107 Views)
Nope.
Message 4 of 8
(4,097 Views)
Drat -- I meant to edit my previous (very brief) remark, but it got away from me.  I tried to look at your code, but I'm allergic to "Pictures of Code".  Please attach the actual VIs so that I (and others) can (a) avoid Eye Strain, (b) see all the wires, (c) see all the Cases, (d) edit/clean up the code to make it easier for us to understand, (e) see what version of LabVIEW you are using, and maybe even (f) run the code.
Message 5 of 8
(4,095 Views)
There really isn't much else to see. I was able to get everything reading by combining two of the tasks. Thanks for the suggestions
Message 6 of 8
(4,059 Views)
Your words are meaningless.  Thanks are given with Kudos and Marked Solutions.
GCentral
Message 7 of 8
(4,044 Views)
Got it. Just marked as solution and kudos.
Message 8 of 8
(4,030 Views)
