Problem plotting 2* 2D arrays in graph
I have retreived 2 arrays fo data from an excel spreadsheet.  One is time that i would like on the x-axis and the other is data that i would like on the y-axis.  They are in 2D format and i would like help on how to manipulate these into a graph. Column1, row 1 (time) would relate to column2, row1 (data) and so on.
Many thanks.
(3,254 Views)
Hi, here is an example.
regards
CLD - Labview Certified Developer
(3,243 Views)
Grant
I would suggest looking at these examples shipped with labview: Write to Text File.vi, Read From Text File.vi, XY Graph.vi and Wavefrom Graph.vi. You can find the in NI Example Finder in Help-> Find Examples ... menu.
Hopefully these will give you an idea where to start
David
(3,236 Views)
I have attached the block diagram to help explain.  I think i need to convert the 2D arrays into 1D before i start making the graph?
(3,233 Views)
Like this?
David
Message Edited by David Crawford on 05-17-2006 10:37 AM
(3,228 Views)
Thanks all, i was putting the 0 constant into the wrong place on the index array.  All is well!
(3,218 Views)
