Problem in saving data
So should I switch back to text file? I was informed that text files contain in them binary files so its ok to save data in them.
Message 11 of 19
(1,802 Views)
There is nothing wrong in using binary file but manually you cannot open them as it is binary format.
Message 12 of 19
(1,799 Views)
If its not too much to ask, can you guys help? I'm trying my best to implement the changes and comments you gave but again I'm new so I might not get it correct. Thanks
Message 13 of 19
(1,780 Views)
Something like this?  It is simple, but it should get you started.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 14 of 19
(1,762 Views)
vt92:
thanks! I'll try my best to understand this.
Message 15 of 19
(1,757 Views)
does the file path need to a spreadsheet? or can the data be saved in the text file?
Message 16 of 19
(1,754 Views)
Bascally spreadsheet is nothing but a tab delimeted file so you can use the file extension as .txt or .csv there will not be any problem (I am unable to see vt92 vi as I have only 2009).
Message 17 of 19
(1,745 Views)
Is there a way to indicate the row number of the word I input. The VI that vt92 made allows permanently saving the data into a .txt file but its not translating properly. I found out that to fix this problem is to indicate the row of the word I input in the "Input" string control. The txt files saves rows as shown in this picture.
Message 18 of 19
(1,733 Views)
Create another column and put the row number in that column.  You will need to keep track of the number in your program because the files do not do so.
Lynn
Message 19 of 19
(1,714 Views)
