Problem in calling C# dll
I'm new to C# but I have to write dll for LabVIEW that reads information about windows processes. I've prepared code (working as Win32 application), built it as dll and used Call Library Function to call it. I've tried another C-language code before and it worked fine. But when I do the same with C#, I have an error in LabVIEW:
"The function name specified for this node cannot be found in the library. Right-click the Call Library Function node and select Configure, then choose the correct function name."
The function I've created (I've pasted it below this post) has proper function but LabVIEW does not see it. Do you have any idea how to fix it? I couldn't find any tutorial for C# and LabVIEW, I saw some for C# and I it should work.
Piotr
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Diagnostics;
using System.Threading;
using System.Xml.Linq;
namespace GetProcessDataLib
public class ProcessData
public static String GetProcessDataFunction(out string result)
String xmlOutput = "";
try
//sample code
catch (Exception ex)
Console.WriteLine(ex.Message + "\r\n" + ex.StackTrace + "\r\n" + ex.Source);
xmlOutput = "";
result = xmlOutput;
GetProcessDataFunction(out result);
return xmlOutput;
Message 1 of 10
(9,930 Views)
Are you sure you built this as a standard DLL, and not a C# assembly? They both use the .dll extension, but you can't call a C# assembly the same way. Instead, you need to use the functions on the .NET palette - Constructor, Property Node, Invoke Node.
Message 2 of 10
(9,917 Views)
Hi Nathan,
Thanks for replying. I'm new to C#... I'm not sure 🙂 I've tried to:
1/ create dll with Visual Studio Command Prompt (both 32 and 64). I used this command:
csc /target:library /out:GetProcessDataLib64.DLL GetProcessData.cs
2/ take dll that was automatically create during build.
Message 3 of 10
(9,898 Views)
What functions do appear in the drop down list when you select your dll in the call library function node configuration dialog?
Message 4 of 10
(9,879 Views)
Any functions appears. Only this default "funcName". I cannot see implemented functions. Maybe there's sth wrong with this:
return xmlOutput;
or I have to change way of creating this dll in Visual Studio.
Message 5 of 10
(9,870 Views)
Have you tried using the .NET functions instead?
Does building the DLL also generate a header file (.h)?
Message 6 of 10
(9,857 Views)
Accepted by Piotr.Zawistowski
@Piotr.Zawistowski wrote:
Hi Nathan,
csc is the C Sharp compiler and will create a .Net assembly by default, not a Windows function DLL. So you need to use the .Net functions in LabVIEW to access it. And anyhow from that source code you cannot directly create a Windows function DLL since there are no exportable functions in there, but only .Net objects.
And Nathan, C(++/#) compilers don't create header files for DLLs. Those header files have to be created by the programmer creating the DLL source code.
Rolf Kalbermatter  My Blog
Message 7 of 10
(9,832 Views)
Thanks Rolf, about the header file - I knew that but was not really awake when I posted. I should probably not post to the forum just after being woken in the middle of the night.
Message 8 of 10
(9,826 Views)
Or at least get a coffee first Smiley Very Happy
Message 9 of 10
(9,822 Views)
Thanks all for help!
What I had to do, was follow this instruction:
If the DLL is a .NET assembly:
  1. In order to use a .NET assembly in LabVIEW, simply use the .NET palette (Connectivity».NET) to find all of the functions available.
  2. First use a constructor node in order to instantiate a class within the .NET assembly.
  3. Use property nodes and invoke nodes to access properties and methods of the class by simply wiring in the class reference from the constructor node to the property or invoke node.
http://digital.ni.com/public.nsf/allkb/DCB90714981A1F148625731E00797C33
And it works. Thx!
Message 10 of 10
(9,806 Views)
